John Deere GT 275
Pmitchell
I have a John Deere GT 275 that starts and runs but gradually looses running power especially going up an incline if I turn it on and turn it back on it runs fine but will start doing the same thing all over again. I’ve replaced air filter, fuel pump, fuel filter and blown air through fuel line into gas tank air comes out gas tank through vent in gas cap also replaced PTO clutch . Any ideas on what the problem is would be greatly appreciated, thanks
mechanic mark
Check cylinder compression & let us know your readings, thanks, Mark
B&S minimum is 135psi. Your Operators Manual may have specifications for your engine, you can post engine manufacturer, model , & serial numbers from engine & we can let you know. thanks, Mark
Purchase this manual, step by step instructions on troubleshooting & repairs, usually about $150.
When you say looses power, do you mean engine slows down or tractor slows down? If the tractor slows down I would check the drive belt and pulleys.
Pmitchell
The tractor slows down. Not sure what to check for on the drive belt and pulleys but I’ll see if I can detect something going on there. Thanks
