micahmesser
- Sep 21, 2021
- 12
Good Morning!
I have been struggling to get my mower to start properly without injecting either carb cleaner into the carb or gas directly into the chamber. What have I done to fix this issue?
Any suggestions?
- Cleaned the Carb (3x now) - this included removing everything from the bowl and tube, physically cleaning all the jet holes and using both carb cleaner and compressed air
- Replaced the intake manifold (small crack that eventually became a big one after removing carb)
- Cleaned chamber according manufacture instructions
- Checked cold compression (reads 100psi both without and with oil)
- Charged battery
- Checked teeth of flywheel
- Replaced magneto (Original was extremely rusty and the spark was a little weak)
- Checked spark plug gap (0.30) and resistance (resistance was within tolerance, 6,000 ohms I believe if my memory serves me right)
- Checked spark - sparking like a mad man
- Cleaned alternator ring of rust
- Replaced fuel line with new fuel line
- Dried out fuel tank and replaced with new non-ethanol fuel
- Drained all oil and replaced with new oil
Any suggestions?
