rmichael777
I bought a Cub Cadet XT1 LT42E a few months ago and everything was fine. Cuts very well. My yard is a little over an acre with several trees and planting areas. The first 5-6 times I could cut the entire yard on a single charge in about an hour and a half with 10% left over. With fall arriving, I switched to mulching blades (but still using the side discharge) and now I barely get 45 minutes out of a charge. I started at 12:16 today with 100% and it was down to 7% at 1:09. Would the heavier mulching blades make such a huge difference? What else could be causing this?
