So continuing "having fun cleaning up the Murray 20 inch" but hit a snag.   I changed the oil and put in a new air filter, new gasoline and some carb cleaner.
I give the rope a pull but it doesn't come out very far. The rope seems long enough.
It's not "hitting" so I plan to get a new spark plug tonight and if still not hitting, do a continuity check on the spark plug wire later this week.
Should I prepare to take the pull start assembly apart and look into a longer rope?
