Shootertexas
 - Jun 18, 2020
- Threads
 - 5
 - 26
Working on a friends mower. A couple of days ago it quit on him after he stopped it to move something. It would not crank.
He (not mechanically inclined) brought it over and and I found a blown 20 amp fuse under the seat.
He went and got some fuses and proceeded to mow again and it did the same thing after about 5 minutes only this time when he put the new fuse in it blew immediately.
Fast forward to today. Using a VOM I found a dead short on the fused wire. After reading a bit, I disconnected both connectors to the engine, the short disappeared.
Plugged the connector to the key switch in... no short. Plugged the connector to the engine and the short reappears.
I unplugged the voltage rectifier/regulator and the short disappeared, put a fuse in the holder and no short. Hooked the rectifier/regulator back up and the fuse blew immediately,
I believe even before I ground the regulator.
Using a VOM none of the lugs on the rectifier are shorted to the case. Terminal B+ to AC shows a short (continuity), Terminal B+ to O DOES NOT show a short (continuity), Terminal AC to O DOES NOT
show a short (continuity).
I am assuming the rectifier is bad but don't know. Can the AC & B+ short together and be causing the short circuit or do you think I need to look into the Stator as the possible culprit?
If so is there a test procedure to check it before I have to take the flywheel off?
All help would be appreciated.
