By the way, when you push the throttle up to choke position and it stops, you do know that you are supposed to "bump" the throttle and move it forward some more (don't try to start when the throttle hits the stop position, that's the maximum run position and does not yet set the choke). Once the throttle stops, push it forward again, to close the choke.
I honestly do not know. All I have done is take the air filter off and I can see a valve near the top of the carb, on the side of the engine closest to the steering wheel, and assumed this is the choke valve? Moving the throttle in any position does not move this valve. Maybe I am looking at the wrong valve?Are you sure you are looking at the choke butterfly ?
I had to go back and reread the op thread. Completely missed this was on a 2020 model. Thanks for correcting me.totally different setup.
