Cajunhunter67
Hello all!
I have a new low hour Zero turn Z248F.
Its has excessive belt slap. Always has from the day I purchased it. I tightened the spring for the tension pulley and helped a little. Problem is its already broken a belt. The new replacement OEM belt installed is also starting to come apart and has been used only a few times. I have again ordered another belt. At this point I'm pretty frustrated. I purchased the Husq over a Cub Cadet due to the heavy duty deck and it also went thru a lot of deck belts.
To me when the blades are engaged the belt should run smooth and the only noise is the blades spinning. This thing sounds like a junk truck.
Has anyone else experienced this issue? If so how did you rectify the problem.
I'm pulling the deck off tomorrow and inspecting all of it.
Don
Don
