XT1 LT50 hard to start cold
TXCub
Hello all-
I have a 2020 XT1 LT50 with the 24HP, Series 7000 Kohler engine. I purchased it new here in the DFW Texas area where it is used.
Beginning a few weeks after purchase and continuing to today, it is hard to start when cold. It takes about 8-10 attempts to start before it catches and thereafter it is fine once it warms up. But there is the smell of gas while trying to cold start when the throttle is all the way forward (the recommended setting I believe).
I have changed the fuel and air filters, swapped the plugs for new ones, and the problem still persists. There is only about 90 hours on it.
It still has the original battery and is kept on a NOCO Genius1 maintainer.
I don't want to put it in the shop unless I have to. My neighbor buddy who is familiar with engines has fiddled with the idle and choke but the issue is still there, and so in the end he put it back the way it was.
Check and adjust the choke to were it closes all the way when the throttle lever is in choke position.
I'm not a hands-on person but I could follow the steps to do this. At least the hood is off and I can see the front of the engine and all the linkage
Take the air filter off and poke your fingers down the tube towards the carburettor
You will feel the choke butterflys
Loosen the choke cable clam and pull the cable back till the butterflys comes then tighten the cable clamp
They often come a little loose and slide forward .
I will try that this evening when I get home.
Many thanks for your reply!
I have 2 kohler 7000 and I live north off You by at least 500 miles. There is a lot of times they sit for a few day and they start with no choke on idle. This is with outside temp around 80 degrees and engine cold. If I ever have to choke one it's only for a split second then right back to idle.
I had my friend go to my house and take the hood off, then remove the air filter. He can look down and see the butterfly valve open. He says moving the throttle handle anywhere between the top and bottom stops does not move the butterfly valve- it stays in the open position. He says if he goes to the front of the engine where all the carb linkage is, grabs the long vertical link rod that he presumes is for the choke and moves this link rod upwards, the valve will close, and then opens back up when he releases the link rod.
I can't see that this is normal, but yet I do not know what is the problem is or the cure. Is it possible the valve is stuck and needs some carb cleaner? Adjust the cable?
Two different ways they set these up
1) off the throttle cable, goes past full open to work the choke
2) with it's own cable which is what Cub usually does
In both cases the fix is the same, move the cable back under the clamp then tighten the clamp.
put the throttle in the choke position and loosen the clamp and pull the cable until the choke closes. Them move the throttle to the wide open position and make sure the choke is coming opening back up. I have seen some throttle controls that don't have enough travel to do this then you have to bend the stop on the throttle control to give it more travel and maybe open up the slot the throttle control is bolted in. Have had to do this on a lot of mowers
Far as I know, the throttle and choke are all in the single handle. I can see the valve open with the sir filter off, but moving the throttle in any position does not open or close the valve. Is this the way ot is supposed to work, or is that the problem? I did loosen the clamp and moved the cable, but the valve still does not move in relation to moving the throttle handle. Only way I can start it is to have someone pull up on the rod to close the valve, and then it starts right up. I am at wits end here!
