Pulling a load. Airens Xd 52” 23 hp Kawasaki
Tedlee
Is it required to be in full throttle even when pulling light loads such as a spreader which loaded weighs less than 80 lbs?
Tedlee
Quickest way to destroy a hydro drive is to run it under load at low engine speeds
Thank you. I had read that but didnt know if a spreader was enough load to worry about
Just your own bum is enough load to worry about
Even throtteling down to drive into a trailer is bad practice.
7394
Plus Engine can't cool as good at lower rpms, & hard on hydros.
