I have a "Brute" push lawnmower which has a Briggs and Stratton engine, 7.25 EXi on it. I am not well versed in small engines but am hoping this is not a major issue.
While push mowing the lawn (it was running normally at that point) the engine sounded like it revved up higher than the normal full throttle speed, then started to run at a
much lower speed, just above idle speed but seems to be running rough. It still starts fine and will chug and run rough but not nearly at the full throttle rpm's. It will not come
up to normal speed. Is this a carbonator issue? It seemed very odd that it would rev up for a very short time, and now only runs at a much lower rpm, and roughly runs.
Any ideas would be greatly appreciated.
