Juat another quality homeowner job
Scrubcadet10
Moderator
Staff member
was it leaking?
Hammermechanicman
was it leaking?
Oh yeah. Once i undo everything the owner did i will figure out what is really wrong with it. He screwed up the valves and the carb linkage and all the muffler bolts are stripped out and one of the valve cover bolts wasn't metric.
And the hits just keep on coming.
And your questions is???
Just make sure that you tell him “You can repair everything but stupid, because the repair kit to fix stupid is not yet available and you have no idea where you can get one.”
Scrubcadet10
Moderator
Staff member
check them sump bolts too.
Are you sure it was the owner and not one of your competitors great workmanship.
Believe or not I seen that same Blue RTV used on a head gasket several years ago here.
Mower King
I sharpened 3 blades for a guy ( I probably have sharpened 1000's over the years ) last week, that he carried in. He took them home, about 2 days later he brought the Big Zero Turn mower in with those blades on it and said my "sharpened" blades don't cut grass worth a f***......I knelt down and looked under the deck, he had put the blades on upside down. I should have asked him how Crow tasted but, as a business....I just told what he did, and smiled!
