I asked the tech at Southern Tractor (where I bought it) about oiling the foam filter and was advised against doing that.  That was when I picked the unit up after the rebuild.  Grease around the hose that clamps onto the filter sounds like a great idea and I'm on that from here on out......thanks for the tip.  My next mower will have a canister style filter.  I started running the pre-filter as an added help, it didn't even come with that on it new.
The pre filte is just that.
A prefilter
It is not meant to  stop sub micron particulates ,
It is there to stops sticks stones & grass clippings that if damp can cause the paper to rot through
The paper is doing the filtering , the foam is screening
General rule is you only oil the foam on foam only filters
And when I fit them, I dip my fingers in the oil then spread some on the carb side of the filter only so the inital air enters vial the dry foam hat prevents very large bits and the closer to the carb the air gets the finer the filtering .
Back in the 60's manometers came into popular useage because they got a lot cheaper .
This then allowed tuners to measure the actual amount of air being sucked into an engine.
Shortly latter racers started to fit foam filters to the carbs which previously had no filteration at all.
Because of the totally irrational "if racers use it it must be better for my engine " foam filters ended up being used everywhere and in a lot of cases places where they were totally inappropriate.
If you are old enough you would remember the advertising, More power, , less fuel consumption, same old same old for every do dad marketed to car owners .
On most carburettored engines no great problem other than a bit more cylinder wear due to more fine dust entering the engine.
Remember that paper filters only came into popular useage in the late 60's replacing the oil bath filters used previously .
The big problem was when they got fitted to the early fuel injected engines and in particular to engines with variable stroke pumps because better air flow meant these engines started to run lean.
Lean enough to destroy many from over heating & lean burn detonation .
Not so much a problem on single barrel carbs but was a bugger with multi barrel carbs where the high speed barrels had different jetting .
By & large the invention & application of electronic fuel injection and in particular mass air flow meters ended this lean burn problem.
However this whole arguement is some what out of place when we are talking about mower engines.
Most mowers are over filtered and with a single barrel cab a higher air flow rate makes no difference because the carb is a fixed rate device so the volume of air passing through makes absolutely no difference .
The caveat to this is ZTR's fitted with baggers  because the bags dump a massive amount of very fine dust right on top of the engine which sucks it right in.
Any ZTR fitted with a bagger either needs a proper double stage filter or a snorkel to draw in clean air.
Down here all of the local mowers were fitted with snorkels till B & S took over Victa.
Honda used to charge a fortune for their snorkel kit which included a smaller jet to compensate for the reduced air flow,,,,,, total tosh unless you were at 1000' or better elevation .
Down side is mowers with snorkels never ever need new filters and as Slowmo has mentioned, continual removal of the filter for cleaning, damaged the seals thus rendering the filter useless, but as the mower is sucking clean air it made no difference as the air bypssing the filter was fairly clean
