LarryJohnson
Can't figure out why mower won't run on gas, but will run on steady stream of carb cleaner. I've been using the old mower for 5 years with no issues. After a number of uses this year, it just stalled out. I assumed the gas was bad, so I emptied the tank, lines, and carb bowl. The only way it will run is with a steady stream of carb cleaner. I visually confirmed the fuel pump is pumping. Don't know what to do next..
Finally got it fixed. Thanks for everyone's help.
