What is the item number you looking at on the diagram and what section?
Ground drive diagram, and it is the rod coming off of part #1. Its the plastic adjusting piece that screws on top of that rod which attaches to the shifter. It attaches to part # 175 which is the shift rod shift. Its plastic and is threaded an the bottom and has a ring on top that attaches to part # 175. I tried to attach pic of part but it says file too large.What is the item number you looking at on the diagram and what section?
| Do you know if I would have to order the entire part...all I need us one of the black plastic pieces that screw on to one of the arms? |
Then you probably are needing the following fiction pack. PN is 587290901 (General Transmissions PN GT79136)
Whats the price if this part?Yep, thats what I'm finding out. Thanks for your help.
