Craftsman T2200 917.250811 shift lever part
Dan Teel
Can't find this part...it attaches to a shift lever for hydrostatic transmission. I see it on diagrams but no # attached to it to order. Talked to Craftsman folks and they can't find it. Help!
What is the item number you looking at on the diagram and what section?
Dan Teel
Ground drive diagram, and it is the rod coming off of part #1. Its the plastic adjusting piece that screws on top of that rod which attaches to the shifter. It attaches to part # 175 which is the shift rod shift. Its plastic and is threaded an the bottom and has a ring on top that attaches to part # 175. I tried to attach pic of part but it says file too large.
Then you probably are needing the following fiction pack. PN is 587290901 (General Transmissions PN GT79136)
Dan Teel
Do you know if I would have to order the entire part...all I need us one of the black plastic pieces that screw on to one of the arms?
You have to order the complete part assembly as General Transmissions will not sale just the part you are needing. I know it is a pain but we are stuck what they will sale to us. Personally it is stupid but of they will not even provide internal parts for the RS800F either.
Dan Teel
Yep, thats what I'm finding out. Thanks for your help.
