Craftsman Garage
- May 2, 2021
- Threads
- 42
- 550
1. yes 2. new to me but used 3.ok 4.no so that is is easier to start .
Pulsa Jet carb alert on a 3hp Briggs horizontal. Tough to hydro lock one. Guess it could be done.first figure out if it's hydrolocked.
Most likely the carb has a partial clog inside where you can't see it. Need to clean the OEM carb. Numerous youtube videos out there. Search for McLane edger carb videos. Requiring choke to run is a dirty carb. People leave fuel in the machine which turns to varnish and does what you are describing.thank you got it started, although I have another problem, feels like its running lean, do you know the correct carb adjust meant? only runs on choke and on fast throttle it shuts off. Thanks
I love this forum, but at times it is confusing to me and I have a few years repairing small engines. This fellow doesn't understand your replies so just advise him to go to a dealer, small one if nearby, and ask them to explain what all of you guys have been saying in trying to help.
I highly doubt that. There is always a "reason".
Your main job is to find it, or it will simply happen again.
A good seasoned tech should be able to get answers fast for the owner. Might cost a few bucks more but would be running.I love this forum even though it calls me a newbie. I have been a member for a while, just not active. I think you have this fellow really confused by all the different answers. Just advise him to go to a dealer, small one if nearby, and get it fixed and ask the right answers.
