Banjoel
Hello everyone and thank you in advance,
I replaced the top drive belt, and the bottom drive belt is still in great shape. When I make a couple passes with the mower it will stop moving forward. The engine is running normally and the mower deck has power to it, but you press on the gas and it goes no where. If you turn it off and wait a couple minutes it will run just fine until the same thing happens. Any ideas?
Thanks,
Joel
Thanks,
Joel
