- Sep 24, 2017
- Threads
- 280
- 6,794
Have you asked your "friend" if he remembers removing a purple wire from somewhere?
That “friend “ is another post I found on here and I did write to them and asked them that questionHave you asked your "friend" if he remembers removing a purple wire from somewhere?
The connector he has is round, the tab on the solenoid is a blade.Look closely at the gold starter, the small cylinder on top is the solenoid. Look closely at the solenoid in the photo and you will see a stab connector between the two threaded posts. Connect your purple-covered wire to that stab connector, start your motor and slap yourself on the back.
