okay.... https://partscatalog.deere.com/jdrc/sidebyside/equipment/72089/referrer/navigation/pgId/189520
i think i see that connector, it's 27B... and listed as the Solenoid Ground. Now where it gets tricky, JD is showing a solenoid mounted on the frame for the SX95, as well as a solenoid on the starter. unless certain versions used a mounted solenoid on the starter, and others a separate type...
I would trace the + positive cable from the battery and see where it goes... does it go to a solenoid, then to the a solenoid on the starter (which i have no idea why it would) or does it go straight to a solenoid mounted on the starter, with no "extra" solenoid in between...
