- Sep 24, 2017
- Threads
- 278
- 6,757
Are you able to check for voltage?
I was not able toAre you able to check for voltage?
Yes all around a foot note it started before with a jump on the old battery mowed for about 10 mins shut off then replaced the battery and deck belt and didn’t start after thatone thing i should've mentioned first, Are you sure the blades are disengaged? and is the mower in Neutral when you try to start it.
YesBattery hooked up correctly?
+to + and - to -
I have an excuse. My wire brush is too big to fit in that small spot.?Okay you two, pour it on with a dump truck. LOL I deserve that one or two LOL. Didn't read ALL of the top post I guess.
Clean your freaking connections ScrubCadet10, LOL.
P.S. I deleted my stupidity. Fully owning up to it though LOL.
