Troy Bilt TB30R Transmission drive belt replacement?
It's all bolted together and will come apart if enough bolts are taken out, just put it back the same way (unless it was screwed up to begin with)......left to loosen, right to tighten!
Haha! Lefty loosey is ingrained in my psyche by my Dad! Which bolts in the attached schematics loosen the unit as a whole?
Well I don’t see any way to get the new belt past the guides on the engine pulley so that baby’s coming off tomorrow with an impact wrench.
I'm in the middle of doing the same belt on the same mower. Will let you know how I make out.
I got the belt on but the brake won't depress enough to start it. The belt is wrong. It's a 35 inch and I need a 35.38 belt. I ordered one from advanced auto this afternoon and it will be in in the morning. I'm hoping that little bit will do the trick. I wish they had an adjustment on one of the pulleys so I wouldn't have to do this all over again. Calls for belt number 954-04331. That's whats coming tomorrow morning.
I just finished putting the lower drive belt on a Troy Belt TB30R I bought a 1/2"X 34" belt and it was too loose. Then I tried a 1/2"X32" belt and it was too tight. A 1/2"X33" belt works just right.
Rural King has sells the belts in graduations of an inch for about $6 each.
It can be a pain the first time, but after doing it three times it makes sense.
By the way, the main pulley on the engine shaft has to be loosened and pulled down low enough to clear the belt guards. There's no way to either get the old belt off or the new one on without removing the nut that holds the pulley on and pulling it down enough for the belt to clear the guards.
