Brandipit
Hi. I have a craftsman with Briggs and straton engine and it just recently started dying when it finally starts. After changing the fuel and fuel line, the bulb hose and cleaning the carburetor the only way it will start and stay running is if it tilted back to where the handle is almost touching the ground. When I put it down to mownit immediately shuts off. Also it won't start without a carburetor spray. HELP!! im at my wits end with this thing. BTW the fuel has been changed out and the oil is full and clean
