The Brain
- Jun 26, 2019
- Threads
- 8
- 77
I purchased the replacement tire 8 years ago (along w/ new belt/trans disc/blade/air filter/spark plug ect.) it's still in the closet.I thought I could use my motorcycle tire irons to much work holding down the wheel I'll have to bolt the wheel to something (I have beaten a 13" trailer tire on w/ a deadblow but never again dam.
the tire obviously won't hold air. however the sidewalls are strong enough to surport weight of snapper.
I have 1/2 acre large back yard and the big outer laps shes to fast in 5th gear.barely hold 3rd on big laps.
what I'm saying is the tires flat yes but doesn't effect speed.
now during my last mow where I treated her like a bushhog that tire may effect pushing though the thick.
so doe's it need replacing?
I believe the wheel is to small to fit a convensionale car tire mount machine.
I know a 13" trailer wheel will fit this machine I think that's the smallest wheel.
I actuelly purchase new trailer tires/w/ wheels just to avoid the hassel of how/wear to get mounted dam. rant.
do you Guy's uselly get wheels w/ tires or mount yourself.
the fronts tread is getting kojectie looking in the middle do you also just buy wheel & tire dam again sorryd dam again cause there's 2 fronts.
thanks
thanks
