builderpete
- May 15, 2021
- Threads
- 4
- 10
I've just taken apart my carb on my ECHO 2306 strimmer. No problems there. Cleaned it all up and tried to re'assemble. There the problems started. The carb bolts onto a plastic block (don't know what it's called) with 2 nuts inserted loosly in the back to take the bolts which hold on the carb, (which I took off and also cleaned). I bolted back on the block making sure the nuts were in place at the back. When I came to bolt on the carb the bolts which also hold the air filter were not now long enough ( about 5 mm short) to pick up the nuts on the back of the plastic block. Please tell me how I have re-assembled the parts so wrongly that I cannot bolt on the carb. Obviously I'm not a great mechanic but quite a good bricklayer. Thanking you for any advice.
