FuzzyDriver
- May 7, 2016
- Threads
- 13
- 221
You could also use a piece of wire from a wire brush.
			Pull the spark plug. If it’s dry, then it’s likely fuel starved. Either a clogged fuel cap vent or a misadjusted fuel float/needle valve. If it’s wet, then the fuel bowl is probably adjusted too low.Hello, and thank you in advance for any help you may have. I have a Silver Series Lawn Boy with a 6.5hp Tecumseh engine and electric start. There is no throttle control or choke. I runs for about 5 seconds when I spray it with starting fluid and then quits. This morning it did run for 5 seconds on it's own fuel, but then quit too. I took the carb apart and cleaned it carefully. It is now the cleanest carb on the planet. I put it all back together, and I get the same problem. The fuel tank is clean and fuel flows properly, and the gas is new premium. Oil level is full. So with my limited (carpenter by trade) knowledge, I'm stumped. Can anyone suggest anything to look into ? Thanks!
It should only have the bail bar you have to pull down when starting no other stop switches.Does this carb have a shut-off solenoid?
These coils ground through the mounting spots on the block so ground is a rare issue. Since it starts and dies I wouldn't think the coil is bad because it would need to run long enough to get hot. To test this you can let it run until it dies and then pull the spark plug off and test the spark immediately after.Pull the spark plug. If it’s dry, then it’s likely fuel starved. Either a clogged fuel cap vent or a misadjusted fuel float/needle valve. If it’s wet, then the fuel bowl is probably adjusted too low.
Beyond that, could be a bad coil or ground.
Use a wire from the Wire Brush.I agree that it is still in the carb. I take a wire twist tie, burn off the plastic or paper on it, then use it to clean out all the tiny holes you can find.
Remove, clean and gap or replace spark plugs.Remove fuel tank cap and try to start it. If it starts and runs, the vent is clogged in the tank cap and you need to open it up. It the cap advice doesn't work, remove the fuel bowl nut and clear the fuel jet openings in the bowl nut with a small wire (.010-.012") diameter, like a twist tie wire. Good luck.
