Intek 20HP Tractor Engine Trouble Starting
Bck1224
I have a Craftsman dls3500 with original carb on an Intek 20hp single cylinder engine, out of nowhere the engine will only start up on full throttle, but spins without starting on Choke and won't start if the choke is fully engaged. I find this weird that it wants less fuel and more lean mixture to start. Battery is reading at 12.6 volts on startup. Any reason why this could be?
Float is not cutting the fuel off properly
Time to remove & clean the carb
Bck1224
Thanks for the response,. Would cleaning out the bowl and float do the trick or would the carb need total disassemble? The engine runs perfectly fine after starting on full choke and idles well enough. Is it getting too much gas?
