It seems that most start problems I have with my Toro mower have to do with the carburetor gumming up. Is there a good gas treatment that I could continually use that will help to ensure the carburetor stays clean? Thanks
I’m using fuel without ethanol and I’m treating it with stabilizer even though it’s not sitting around for months. I was wondering if using Sea Foam occasionally was also beneficial for small engines?If you are using good fuel, that has not been sitting around for more than 30 days, you should not have any problems. If this is the case I would recommend you go to a different supplier. Good ethanol fuel will not breakdown within 30 days.
Was that a challenge?Use of fuel stabilizer or different oils has been debated here many times. I hope this doesn’t start another one.
