vahawkeye
- Apr 29, 2021
- 4
My first post on this site. I am having difficulty with charging system on the craftsman that I bought new in 2005. I had it in the shop and they replaced the alternator and regulator 19 months ago. I should have taken it back as it was not charging like when it was new. I used it all last summer and it would start until the last time I used it in the fall 2020 for leaf pickup. Watched youtube video and tested the regulator and it was at about 7volts which it should be about 13 to 14 volts. I tested the output on the alternator and it was 27 volts at idle and 32 volts full throttle. I ordered new regulator part # 84907 genuine BS part which should be compatible as the alternator was part # 5928030. Got the new regulator today and it didn't fix the issue as the voltage out of the regulator is still around 7 volts. I have attached the wiring diagram which was in the manual and if someone could suggest a next move. This particular lawn tractor has three different configurations alternator/regulator listed on the Briggs and Stratton charts for for this engine. I am wondering if I have the correct regulator? for that alternator. Has anyone worked on this engine electrical system before? Is there a stamp on the engine with it's model number? I tested the continuity from for the wire which goes to the battery from the regulator and it passed. Any help would be appreciated.
I did a trickle charge/repair of the battery and it holds steady at 11.8 volts which I know is low and I will replace it once I get the charging system correct.
