Powermore 140 cc mtd lawnmower
iamrdman
wont start on first or second pull.cleaned carb,new plug,oil.Needs to be primed a lot before it will start,sometimes it wont.how do you adjust govern bracket?
any suggestions ?
mechanic mark
Scrubcadet10
Moderator
Staff member
if it's been sitting all winter with fuel in it, BE SURE you're using Fresh fuel.
and may need to remove the carb and clean it .
iamrdman
Powermore 140 cc
Yardmachine mtd
S/N # A-A1S5500
iamrdman
Yes, you need to adjust your valves with engine cold. Post all numbers from engine: model xxxxxx, type xxxx, trim xx.
Will try that,but dont no the specs for the valves or how to do it.thk you
