Did thatif it's been sitting all winter with fuel in it, BE SURE you're using Fresh fuel.
and may need to remove the carb and clean it .
Will try that,but dont no the specs for the valves or how to do it.thk youYes, you need to adjust your valves with engine cold. Post all numbers from engine: model xxxxxx, type xxxx, trim xx.
Bought it 2017 in the fallHow old is the mower?
