Front End Alignment Help Needed
levlarry
What would be the best tweak? Replacing the axle?
levlarry
You maybe able to tweak somethings and get it fairly close, but will probable never be perfect and will revert back to some degree of toe out after some time.
Is it the axle keeping the wheels close to off the ground?
I think a picture would help to describe what you are referring to. Axle not setting level or something else going on.
levlarry
Thanks for the help. Starting to rain. Will take picture of tire off ground tomorrow. Problem is, I know nothing about the mechanics of it or probably wouldn't have bought it. Just hoping to fix it without to much cost in order to use it for a few years. Thanks again.
