JB Lawn
Hey guys, I’m brand new to this forum so don’t bust my balls too bad for asking any stupid question. Lol. I have a 61 inch turf tiger with a velocity plus deck. It has been cutting like sh*% all week. I replaced the blades last week with a set of stens, and it cut better. The left side was scalping the ground and I had to float the deck to keep it from scalping again. I got home and parked on flat concrete in the shop and attempted to level and set the deck pitch as I’ve done many times. I have brand new tires (one week old) with 12 psi, I measured the height of the front flat free tires and they were the same. The problem is this deck will not level out. No bends in the deck that I can tell, blades are straight, I ruled out everything I could think of that could possibly be the problem. It appears that the front chains need a link taken out to bring the front up, because I can’t get it to raise otherwise. Has anyone taken a link out before? Also, with the deck belt off, should there be any play in the spindle shaft? I’ve heard yes and no to this question, thought I would ask you guys about that too. Thanks in advance!
