- Sep 24, 2017
- Threads
- 280
- 6,787
Some awfully wacky with my push mower, Internal wise.
It's a 3 year old 799983 shortblock (122T02-1207-B1) i bought off of a member on here in Feb. 2019., i go out, check the oil (which i changed in the Fall of last year) right on Full. Topped of the gas, 2nd pull she fired right up, running excellent. I mowed for about 10 minutes, and shut it down, to go move some of the niece and nephew's toys.
Come back to the mower, grab the rope, and it pulls out about 4" and comes to a dead stop, NO way i'm pulling that sucker. I took out the spark plug, put on a glove, and grabbed the blade, i could turn it about 1/3 of a turn either way before it stopped, piston is moving and from what i could see the valves were operating properly, finally after a few times of turning it back and forth, i finally got it to go several rotations with ease. reinstalled spark plug, fired it up, and this thing is vibrating bad. it's not big vibration, just one of those that makes your hands and arms into jello. so i shut it down and finished with the Stihl weedeater. Now i'm typing this. I guess i'll zip the head off and check the cylinder for scoring or anything obvious.
P.S. Blade is still straight, and crankshaft doesn't appear bent in the slightest.
