transmission k46 problem
stephena
hi,i have just done oil change on the k46,started it up and found it is not working correctly.. it is going in reverse when the pedal is pushed for the tranmission to move forward.how do i correct this. there is some thing i have missed when reinstalling the parts.. thank for your help cheers
stephena
What did you take apart to change the fluid?
hi. no drain on the casing, removed the bottom cover.. also as i bought this mower second hand,when i found that the oil reserve tank was full of dirt i decided to clean the whole trans mission..replaced every thing as it was,or i thought so.. obviously i stuffed it up..cheers
Hammermechanicman
There is a piece in the pump if you put it in backwards you get the problem you describe.
Hammermechanicman
hi can you please let me know which piece it is,is it shown on a diagram of the transmission,cheers
I meant to say the motor not the pump. The block that slides in with the motor pistons can be put in backwards and that will cause the trans to operate backwards
stephena
thank you, thats what i managed to,so i will turn it around. regards stephen west australia. .
mechanic mark
you need to bleed air from transaxle while rear axle is on jack stands, front wheels are scotched, have helper move rod lever at backside, pull out & wait 10 seconds & push back in for 10 seconds while you are in seat operating forward & reverse pedals & helper is operating rod back & forth.
VRR.DYNDNS>BIZ
It sounds like it is the hydro unit with a two bolt cover for the gear pump. That cover if rotated and installed backwords from how it came of, reverses pump flow. Remove it and install 180 degrees from how it is now.
stephena
hi .thank you for your reply.it is a tuff torq k46.i have reopened the transmission.and removed the clamb shell.this motor has no two bolt cover but it does have three bolts hold the pump and motor into the the base.. can please clarify where i would find the cover for the pump.
i have included some photos of the hydraulic pump and motor mount..
