transmission k46 problem
hi .thank you for your reply.it is a tuff torq k46.i have reopened the transmission.and removed the clamb shell.this motor has no two bolt cover but it does have three bolts hold the pump and motor into the the base.. can please clarify where i would find the cover for the pump.
i have included some photos of the hydraulic pump and motor mount..
Ok you're pictures are not of the problem the pump pistons press on a wedge shaped block one end is narrow and the other side is thick the thick side needed to be installed facing up tyrell has a video showing how to do it
