- Feb 19, 2020
- Threads
- 121
- 12,890
Since I work out of a 24 x 24 that is full of tools and parts, plus got one room of home full of parts now just make some room a new 44" tool box system; space is at a premium. Most of my work is now outdoors.
As for the numbers that's why I showed you the supersedes on post #11. This the latest price file update from Husqvarna which contains the latest supersedes that they provide my distributor which provides me the same file. Even this don't help when they put the right SKU number on the wrong belt. This why I measure every belt now as it has happen too many times here. All they got to do is to load the machine with the wrong part then a 1000 or so units gets printed wrong. IT happens but should have caught by quality control but it even pas them when they are on a coffee break.
As for belt variances it is understood but many OEM usually spec the shortest in the first place. I just did a JD recently that spec'd a mule drive v-belt and theirs came in a 1/4" shorter than spec and would not even fit over the spring loaded pulley with the assembly hitting its stop. Ended up having to unmount the pulley just to get the belt on. Definitely wasn't done by the service manual instructions.
