Craftsman w/kohler command cv16s no spark
We need the model of the Craftsman mower to look up it wiring schematics. Also need the spec of the Kohler to see which ignition system it has.
Edit: Most of FHP CV16 uses a DSAI module with a two or three terminal coil. So also need if you have the two or three terminal coil.
I'm needing a coil that replace the dsai coil.
