Replaced coil. Still no spark. How to check relays or safety seat switch?
D Dagflabit$1 Forum Newbie Joined Jan 29, 2021 Threads 1 Messages 1 Jan 30, 2021 / Craftsman w/kohler command cv16s no spark #1 Replaced coil. Still no spark. How to check relays or safety seat switch?
StarTech Lawn Royalty Top Poster Of Month Joined Feb 19, 2020 Threads 79 Messages 10,255 Jan 30, 2021 / Craftsman w/kohler command cv16s no spark #2 We need the model of the Craftsman mower to look up it wiring schematics. Also need the spec of the Kohler to see which ignition system it has. Edit: Most of FHP CV16 uses a DSAI module with a two or three terminal coil. So also need if you have the two or three terminal coil. Last edited: Jan 30, 2021
G gaclements Forum Newbie Joined Sep 10, 2014 Threads 0 Messages 2 Jul 15, 2023 / Craftsman w/kohler command cv16s no spark #3 StarTech said: We need the model of the Craftsman mower to look up it wiring schematics. Also need the spec of the Kohler to see which ignition system it has. Edit: Most of FHP CV16 uses a DSAI module with a two or three terminal coil. So also need if you have the two or three terminal Click to expand... I'm needing a coil that replace the dsai coil.
