bbbobbbo69
- Dec 19, 2020
- 22
G'day fellow slashers from Sunny Aus. Have just joined after going goggle eyed via you tube vids trying to suss out the proper procedure for replacing bearings on my $ earner. I've read the operator manual & the additional docs. to do with these spindles & am still at a loss as to the proper way to tackle job. I believe I have the 119-8560 spindle assembly that has the 15/16 bolt & washer holding the blade on underneath & a 33mm nut on topside.
Most "how to's" state to take the 15/16 bolt & blade off 1st which has me stuffed how you go with ol' 33mm with nothing to wedge under deck against blade to stop the 33 from spinning !
Oh also the pulley had 3 x 9/16 nuts securing it down onto spindle hub. Does this hub have to be 'convinced' to lift off thus allowing the shaft to drop out the bottom, or am I missing something here regards the 33mm nut on top .
Any help/suggestions would be hugely appreciated guys & if more info. or pics. needed please sing out & I will post. I did search forum & reckon the help is here from what I read but man my eyes are burning & I couldn't read past page 7 !!
Killer forum, I think I'll like it here. Lol !!
