PTmowerMech
- Apr 16, 2018
- Threads
- 431
- 3,303
Have you connected an ohmmeter between the coil kill wire and ground and what readings do you get with the key switch in the off, on and actuating and deactivating the seat switch?
I've only checked the ground continuity of the kill wire with the switch on and off. Its grounded either way.
