S skip6832 Forum Newbie Nov 30, 2020 #1 Engine has a loud knock on startup then sounds normal after it gets up to speed does anyone have any ideas what could be causing this?
B bertsmobile1 Lawn Royalty Nov 30, 2020 #2 If it knocks when you turn the blades on & off check the engine mounting bolts
ILENGINE Lawn Royalty Nov 30, 2020 #3 bertsmobile1 said: If it knocks when you turn the blades on & off check the engine mounting bolts Click to expand... And also when cranking to start or during the last couple of seconds when shut down.
