JD la115 wont start , new carb, start fluid
Leftysdad
my jd la115 quit cranking on me...when i shoot a spay of starting fluid in it, itll crank for a sec and die, when start fluid is burned.....so i cleaned it, same result....just installed my brand new carb i orderd and yep....same exact thing...any suggestions....it has good gas, has not sat , thanks
Running on starting fluid down the plug hole indicated correct spark timing
Running on starter fluid sprayed into the carb indicated ok valve timing
Doing both but not running on it's own fuel usually indicated a stuck / broken solenoid on the carb or blocked fuel inlet .
Leftysdad
Starting fluid down the carb , not plug hole
Check the afterfire solenoid in the carb.
Scrubcadet10
Moderator
Staff member
X2 on the afterfire solenoid if equipped, but I would check for power going to it.
You should hear an audible click too when the key is turned to the On position
Leftysdad
Could it be bad on a brand new carb
