Last time I finished mowing, I put the brake on and put the control handles in neutral.  The engine should have kept running (I like to run all the gas out of the lines after each use), but it just shut off. Brake being on or off made no difference.  I just sat there and ran the engine until the gas ran out.
Today I went to mow, and the PTO wouldn't engage. Made no difference what position the brake or control arms were in. Plus the same issue as above still exists. Any ideas on what I'm looking at here: clutch switch, clutch relay, kill relay, seat lift kill, neutral switch, brake switch, something else?
Any thoughts will be appreciated. Thanks!
