PTmowerMech
Briggs 21B707 0453 E3 on a Troybilt Pony 13WM77KS011
When I give it full throttle too quick, it starts running like it's being choked. LOTS of white smoke and some black smoke in there too.
Engage the blades, and the engine starts shaking, deck starts shaking. And it smokes like the devil.
Disengage the blades, throttle it down, and it goes back to normal.
What I've done...
Took the carb bowl off and turn the needle around. Yup, it came in that way. The guy says his son was tinkering with it.
Without taking the carb completely apart, (and making sure the needle valve didn't have a ring around the tip. I cleaned out what I could get to without taking it all apart.
Adjusted the valves, which were way out. Push rods were still straight.
Replaced the spindles and bearings. Check the idlers and they were fine. Before putting the deck back on, I made sure everything was spinning freely.
Compression is at 90lbs.
What I've done...
