- Nov 29, 2014
- Threads
- 64
- 24,718
Parts are probably a lot cheaper over there but those plates regularly get welded then the hole machined or a top hat bush made for a bigger hole depending weather I am in a welding or machining mood .
The Owners manual tell you to oil the hole ( year right ) weekly however if you blow the area around it out with compressed air at least once a season followed up with a saturation spray of dry lithium chassis grease ( let it sit for a long while for thee solvent to evaporate ) you will hopefully never have to repeat the job you have now become very skilled at doing.
Sorry if my assumption about the parts being the same as husky ones caused you grief
