Bigwaynester
 - Oct 8, 2020
- Threads
 - 1
 - 5
serial# 7901784 you have to keep hitting the prime button before it dies after several times of hitting the prime bulb it will stay running.  I've had the carb apart a few times, cleaned it well, used a compressor and blew out the lines in the carb. So far besides cleaning, i put on a new bulb and the 2 gaskets that goon either side of the carb plate.. I also cleaned the air filter. I was going to try new fuel next, this is my 90yr old uncles not sure how old the fuel is
