Scott1970
Just like a couple other posts I’ve seen my Husqvarna 125B leaf blower will not stay running. Not even a year old. Used 4 times. Replaced carb, fuel lines, primer ball, fuel filter & spark plug. Removed muffler. Clean. Removed spark arrestor. Was clean. Replaced gas cap. Primer ball will not pull fuel. Pulled line off, plugged it. Holds pressure. Does not make a difference if choke is off, on or 1/2 way. Takes over 15-20 pulls to restart. Doin exactly as it was before everything was replaced. Replaced all parts exactly how they were removed with all OEM parts. Full of gas, 1/2 full or almost empty, no difference. Has compression. Hast been used for a full season. Had a brand new husqvarna string trimmer that did the exact same thing. Both practically brand new, both from Home Depot which could be the problem. Any ideas? Fixable? Worth fixing? Scrap pile? Any ideas? Thanks
