Lawnmower collector
I recently acquired a commercial size pressure washer with an 18hp Briggs Opposed twin, it needed a carb clean and fuel pump kit. I got it running and it runs pretty well but it's not charging. It's got a heavy duty push button starter switch on it I saw they had the charging wire connected to the starter side of the switch, so I removed it and put it on the battery side of the switch with no change. So then I got to testing the wires coming from the stator to find they had the black wire connected to the charging wire, (the black wire is cut on the pressure washer side of the stator plug) so I switched the red wire so it was connected red to red at the plug, now when I connect the battery I get sparks like it's drawing somewhere. I tested the stator and I've got continuity between the red wire and the ground cable. Thoughts? Is the stator fried?
