>What you should be doing is taking compression readings at regular intervals like servicing or every season end etc
That was my hope. And even if the gauge is off, but consistently off it should be OK for me since it would still show a relative decline.
As for my extreme budget tester.... I found a video that was helpful to strip out the ceramic insert in the plug. I didn’t have a holesaw that would fit, but I found that a hacksaw around nut did the trick!
That will work fine
It will work better if you put the same amount of oil into the cylinder for each test say 3 to 5 drops from an eye dropper so the rings have the same oil seal each time.
When I ran a fleet of light vans & motorcycles we did compression tests bi- monthly.
That way I could catch the wear early and we got 3 to 4 sets of rings out of each piston & bore .
Might sound tight fisted but we ran 8 x 4 cylinder motorcycles and a set of rings & gaskets was under $ 100
A rebore was $120 and a set of pistons $ 200 so it added up quickly.
It also meant that the bikes always ran crisply which is important if you are riding all day every day in capital city traffic .
Did the same thing with the vans but being water cooled, the ring wear was substantially less ( the riders vs Drivers also contributed more than a little )
