ronbo57
- Oct 2, 2020
- 2
The problem I am having is the unit won't re-start if you stop it after mowing, and get back on to start. It acts as though the battery has not enough amperage to turn it over. Most times it will start the next day. But this week it took 3 days. Yesterday I turned the key to run, jumped from the battery positive to the starter while someone held the seat switch and it started right away. This morning I went out and it started no problem. I have replaced the brake box earlier this year as it was obviously bad as it was totally function-less. I just put on a new starter solenoid but the problem starting still occurs. It's almost as if the control voltage to the solenoid drops out on a whim. Anyone else experienced this problem?
